JasonK
Participation Award Recipient
Sitting at about 59g at the current build status.
quorneng
The Sea Hawk nose section added.
The canopy and part of the top skin act as the battery hatch and to give access to get everything in
A simple two colour scheme. Dark Sea Grey upper, Sky below.
The ESC is mounted into the cockpit wall with is cooling fins just ahead of the RH inlet.
The battery box for the 1800 mAh 3s is slightly offset to the left to counter the weight of the ESC.
Despite the inefficiencies of the ducting it actually flies quite well. Gentle and predictable not unlike the full size.
With clean aerodynamics and a very low wing loading it glides like .... a glider!
The Hangar
Fly harder!
The canopy and part of the top skin act as the battery hatch and to give access to get everything in View attachment 204127
That looks like it flies really nice!
Brian B
This is my "cooldown build" before I start cutting out parts for another big project. My prediction is 110mph on 4s, 120 with an irresponsible prop. View attachment 204066 View attachment 204067 View attachment 204068 View attachment 204069
Every LE and TE is tapered for minimum drag, including the little bit of foam which sicks out next to the firewall (even the hatch tape is shorter than normal) and I didn't do the scale paint job for orientation's sake.
Ooooo, nice. Foamboard? You made the plans yourself or are they an availability download?
quorneng
I think you mean SR 71.
Its figures are not that high.
The B52 has a wing loading of 120 lbs/sq ft and a thrust to weight of 0.31
The AN225 has a wing loading of 136 lbs/sq ft and a thrust to weight of only 0.23!
Quinnyperks
Oh wow, I never looked at those. I was more meaning how it was able to achieve those speeds with that power.
quorneng
The aerodynamics of supersonic flight are complex indeed.
Remember Concorde had the fuel to cross the Atlantic at Mach 0.85 or Mach 2 but not at any speed in between as the combination of drag and engine performance was too inefficient. Concorde had a take off thrust to weight of only 0.33
Quinnyperks
Yeah, the aerodynamics side of this is what I usually try to stay out of. It’s too complex for what I do. If it flies, it flies is usually what I use. Exept on my ultralight designs.
