AR637T gyro correcting in the wrong direction
Hi there. The AS3X and SAFE on my AR637T receiver has the elevator correcting backwards. All other channels are correcting correctly and I have triple checked the orientation. Also the servos are all set correctly and when I pull back on the stick the elevator hues up. But when I angle the plane down, the gyro gives it more down. Any ideas?
Bricks
Your way works but the AR637T receiver is programmable and you could of done it thru your transmitter with forward programing ( if you have a newer DX series ) or PC program.
