Spitfire76
My current build requires a 20mm up deflection of the ailerons and a 8mm down deflection and I am trying to work out how to accomplish this with the Aura 5 lite. I thought I could simply configure it in the flight mode screen.
The left and right aileron rate affects both servos and of course one is up and one is down. For example if I set it to 10/70 and move the stick to the left there is a small deflection up for the left aileron and down for the right, moving the stick to the right there is a large deflection down for the left and up for the right. What I need is by moving the stick to the left there is a large deflection up on the left aileron and a small deflection down on the right aileron, moving the stick to the right a larger deflection up on the right aileron and a small deflection down on the left aileron . Of course the elevator rates do correspond to the up and down deflection since there is only the one servo. Maybe there is a way to configure it in the mixer section of the Aura config but I don't see how. I have sent an e-mail to Flexinnovations support so will post any solution here.
