Aura 5 transmitter endpoint settings
ILv2Xlr8
What should I set the endpoints on an OpenTx RadioMaster transmitter using Spektrum or FrySky receivers with an Aura 5?
Manuals say Spektrum Tx set to 125% on AER and 100% Tho/CH5-6, but for FrSky 100% on AER and 84% Thr/Ch5-6.
Is it the TX or the RX brand that determines the end points?
sconner
I set all of mine (Spektrum DX7 DSM2) to 150% as that gave a full throw on the input monitor (enable "Live Data" in the top right box "Aura Status Monitor". The only exception for me was my 3 position switch that I use for the flight modes. For whatever reason it wouldn't recognize the third flight position until I set it back to 100% / -100%. Haven't flow it yet but I thought I'd share.
I am curious, there is an inner box and an outer box. Is the goal to have your throws register to the inner box or the outer box?
sconner
Bricks
Radio determines end points receiver does not care.
Max is already set on the RadiomasterTX16s or most OTX transmitters -100 +100 equals -2,000-+2,000. Spektrum standard is around that -1,900-+1900 when going to 150% on Spektrum then it goes to - 2,000-+2.000 ium
