leaded50
The P.1214 was one of several "Hawker" proposals for the supersonic Harrier II. Distinguished by its forward-swept wings and double-boom "flying squirrel"-like body . It was named such due to the crossing nature of the mainplanes through the middle/aft section of the fuselage - making a distinct "X" arrangement when viewed from the top down profile.
Plane was developed late 70´s along the lines of Advanced Short Take-Off/ Vertical Landing fighter design. To achive a "thrusting component" it needed be powered by a "Plenum Chamber Burning"(PCM) components under the aircraft with three swiveling thruster - exhaustports to achive this.
The main physical quality of the fighter where the mainplanes with sweept forward in design, hoping for finding performance gains. Well blended wing roots joined to the structure where its rearward swept tailplanes completing the "X" appearence.
The result was one of the most futuristic fighter concepts of the period.
The P.1214 marked a series of research studies on wing planforms/ structure/ ASTO/ VL/ performance/ physical functions eg. and gave much researchs in aero dynamics.
By 1984 novelty of the proposal was worn off, and also found that forward swept wings offered little improvement over conventional rearward swept wings.
As been the only true "X - Wing" fighter , of course this is something interesting for me to build model of. ( since admire all planes with a special history, prototypes and just designideas.)
1050mm long, 880mm wingspan, one single 64mm EDF (reworked w/ more powerful motor, 12 blade & balanced) .
