Beaglet 40 (Eaglet 50 scaled down to 80%)
Beaglet 40 (Eaglet 50 scaled down to 80%) 5
Please log in to download
johnbecker31
johnbecker31 submitted a new resource:
Beaglet 40 (80% Eaglet 50) - Beaglet 40 (80% Eaglet 50)
Many of us have memories of flying the Goldberg Eaglet 50 when we were just learning to fly. For those wanting to take a trip down memory lane, I present to you the Beaglet 40! This is an 80% Goldberg Eaglet 50, designed using FT standard methods. The maiden flight was gentle, and it flew every bit as stable as I remember the Eagle 50 flying.
Currently, I have not tested this aircraft with landing gear, so you will need to figure it out on your own. I have marked a location for the...
Read more about this resource...
johnbecker31
concept for main gear (tail dragger)
johnbecker31
Flight characteristic are much better with the latest version. The cleaned up airfoil makes for a smooth decent when landing.
If you have downloaded a previous version, I highly advise you download version 5.
Peted
I recently crashed my simple scout 10 seconds into the maiden, and the thing snapped cleanly into three pieces. Although i do plan on gluing it back together, do you know if the power pod for the scout will work for the beaglet?
johnbecker31
if you built it using the B Power Pack, or anything of that approximate size, it should work just fine. I typically run an 8x45 prop on this bird.
