Bigger image attachments
There seems to be a setting that keeps attached images very small
Can this be changed?
Best regards
//UndCon
colorex
Rotor Riot!
You can upload them to photobucket or the like, and use the Attach from URL function. Then they will show up full size.
#4
Ill try one here
the original is 1024*768
I click image icon above text area - select a file from my computer and transfer it to the server.
When posted it turns out as a miniature and even if I click on that image it is very small.
1st picture is: 300px × 225px
and the big picture is: 368px × 276px
Attachments from my webserver does not work at all - says invalid url
error can be seen here
http:/undcon.com/temp/error.png
(i have never seen that before with links from my server)
//UndCon
pgerts
Old age member
Do not check the option to upload and make a local copy of the image in the link if you want bigger images.
SIG AstroHog - NO ARF
So the "retrieve remote file" option is configured to keep small images locally.
Ill link to a big picture
Cool - that solves a bit...thanks for your tip pgerts.
I can do that - but I still think the locally stored files can be default sizes - and when needed limited by width in forum
colorex
Rotor Riot!
Using "Insert Image" button using direct link with box unchecked:
Using "Insert Image" button using direct link with box checked:
I get a message saying "Invalid URL"
Using IMG code from Photobucket:
Uploading directly:
