I tore the Ender 3 apart and made sure everything mechanical was in top shape. I replaced the old tired extruder assembly with a Creality direct drive extruder. Now the setup starts all over again......
I've had a BL Touch for quite a while. It worked on the V2.0 version of this board but the USB hood fell off of that board so I bought the V 3.0 version (much nicer board) Now with the V 3.0 board BLT homes then goes to position 1 of 25 then stops with a Z stop failure. The Z stop switch is fine. I've checked it with an ohm meter. "firmware-ender3-bltouch-for-z-homing.bin" has been installed along with "Maple". There have been no recent firmware updates that I can find for this board in the Ender 3. It obviously doesn't like having the Z end stop switch in the picture. If I lower the Z stop any further the nozzle will crash into the bed. Either I'm missing something or I'll have to wait for a firmware update. Oh, and I've been using the Creality 4mm glass bed if that makes any possible difference.
Anyone using the SKR V 3.0 mainboard had this issue? The BLT is mounted and wired in. It would just be nice to have it working.
