Bind All
I've been hearing about this thing that I believe it call BindAll. From what I understand, you put it on the back of your Tx and it will let you use ANY Rx. Is this true and how does it work? Sorry if I got the name wrong.
#2
It sounds like a multi-protocol module. I have a 4 in 1 module that has the four different transmitter chips, and protocols to bind to just about anything. I think Graupner is not supported, but almost everything else using 2.4ghz can be bound with it.
#3
Does this mean that my Tx will work with most off brand brands that use STL protocol? Such as Ares (or so I believe it's called)?
#4
I'm not sure what STL protocol is, but yes it should fly most chinese models. I have a Spidex that I believe is an Ares model. I will see if I can get it to bind with the muli-module. I won't have the time to try until the weekend though.
#5
Totally fine. Just wandering, where I can get one and what are the better brands? I see lots of cool planes but they aren't always DSMX.
#6
What radio do you have? Depending on the radio there are different modules that work. I have an iRangex irx4. There are versions that use the PPM out from your Tx to connect, and those will work with any radio that has a trainer port.
#7
I have a Spektrum DX6e w/DSMX. I don't have a trainer port, only wireless trainer option.
