Maingear
Flugzeug Liebhaber
I have: taped then hotglued the bottom center section to the fully assembled wings, taped the top center skin to the LE of the center section (after making corresponding 50% score lines to achieve proper airfoil) and folded it over, trimmed the wing's upper skin to match the center top skin, installed a fwd spar made of two DTFB strips (tying the LE of the wing spars together with the intent of installing a second spar tying in the rear of the wing spar), and finally will install a third towards the back for motor mount.
I only needed one sheet of DTFB for the top center skin, the rest came from the Kraken's scrap.
This configuration will use a trike gear configuration with a steerable nose wheel and no keel fairing.
I will be installing two motors on the center section's top skin trailing edge (TE), similar to the blunt nose versa. What do you think the thrust angle should be?
Justin
Justin
