Taped on the esc and temporarily attached the motor and a 3s 2200 will balance when the rear of the battery is touching the front of the hatch cutout. I’ll shift my hatch forward.
Moved the hatch forward a bit and everything balances nicely with a 3s 2200. Chopped the nose at an angle since I didn’t get the point to work well. Reminds me a bit of the Battlestar Gallactica fighter nose - kinda like it. 650g with the battery.
Need to hook up the ailerons and then will give the wing pods a try. May try to carve them out of pink foam depending on how much a pain beveling each of this fingers becomes.
I used a Turnigy 2826 2200kv motor with a 6x4 prop and a 2200 3s to balance. I could have used a little more speed. What motor were you using on the yours?
650g (23oz) is nice and light - my EDF versions are typically in the 32oz (900g) region.
Initially I was using an NTM 2826 1200Kv with 9x6 props on 3S (2200mAh). I think the most powerful pusher motor I had was the NTM 2836 2300kv with a 5 or 6 inch prop on 4S.
