I have built many FT models, at least a dozen. I have a large size Flerken, which I love, so when the Boomin Flerken came out I bought two combo kits with wheels.
Yesterday I maidened the first one. Very scary I must say. It took off our mowed grass runway and immediately went straight up and tried to do a loop! Startled the heck out of me as I expected it to take off like Josh’s video. Anyway after trying to trim it with little success, I slowed it down and it became more manageable. I was able to land it successfully.
What I noted was that whenever I applied near full throttle it climbed hard. I could only trim it for slow to medium speed on the transmitter.
The other thing I noticed when building it is that there appears to be a lot of positive incidence on both motors, very noticeable. In my mind this would explain the extreme climbing when at high throttle.
My question is, is this flight characteristic normal for the Boomin Flerken? (I hope not, as I like to go-fast in a straight line without climbing!) Also, is the noticeable positive incidence of the motors (per the kit) normal? (I'm thinking about shimming the motors to take it out.)
The last thing is the balance point. I balanced it a little nose heavy per the instructions at 1” back from the leading edge on outside of boom. My 4s battery is hanging half off the ply battery tray toward the center of the plane. Is that normal? The battery tray placement for the Boomen Flerken is not in the correct place?
My last comment is the wheel kit. From my one slightly hard landing, the nose wheel sitting on unsupported foam is not sufficient. My nose cracked in the glue line under the front nose wheel. This won’t stand up very well and should be reinforced in the kit, which I will do with some light ply.
Dave
Here is one of the planes I scratch built! https://www.flitetest.com/articles/ft-x-29-lg-v2-large-scratch-built-w-retracts
Also look for my thread on this page with more photos. (I’m dhall224) https://forum.flitetest.com/index.php?threads/unofficial-ft-x-29.36950/page-5#post-747273
Dave
