bracesport
So 2021, what to do, what to do?
My BAMF fuse was damaged and repaired before I got it, and I did some damage to the boom on a bad landing (also repaired), so maybe I can build a new fuse for it!
I found a pool cue that can form the boom taper, and then I can 3D print the moulds for the fuse..
The pool cue fits my 15mm CF braided sleeve so that should work well.
The purple section will also fit to the pool cue and be part of the main moulding (one piece with the boom.
The orange section will be moulded separately and the inserted and glued into the purple section to complete the fuse - the flat part of the orange section will house the servos.
The grey section is another separate moulding to form the nose cone.
Making a test print of the purple section to check the fit to my BAMF wing and also to the taper of the pool cue.
