Broken shaft on Power Pack C Motor
Mode 1
Hi All.
I'm in need of a little help. Last night during combat we ended up breaking the shaft on a power pack C motor. We had unscrewed the four screws from another motor we had and put it on the motor in need. That being said, upon my search on the FT store for a Power Pack C shaft I'm not finding what I need. I'm going to assume what I need is not called a shaft. Can someone please point me in the right direction to get the part I need? Many thanks!
Dave
Sero
Just to clarify, are you speaking of the Emax GT2215? And by the sounds of your description your speaking of the propeller adapter that you bolt on with the 4 screws, not the shaft that holds everything together, correct?
Gazoo
Hi All.
Dave
I think what you are looking for is called a "Rotor End Prop Adapter". Looks like it is impossible to find one though. Sorry my friend. This is the closest that I have found.
https://www.headsuphobby.com/Rotor-End-Prop-Adapter-for-the-Emax-GT28-Series-of-Motors-_p_2491.html
