Bronco OV-10 w/ rudders
Nicholas7231
Anyone made a ft bronco with the ov 10 tail and added twin rudders to the tail? Should I re enforce the stabilator section if I use some of it for rudders. Just a though as I'm going through the build
Grifflyer
WWII fanatic
I'm sure some has made it with rudders, but I don't know where one is. Why not run differential thrust instead of rudders?
Nicholas7231
This plane is going to be used for a project that I have in mind maximising redundancy is one of the goals, so if a motor goes out rudders could be used to counteract that
Grifflyer
WWII fanatic
Okay, I personally wouldn't reinforce the stabilizers I would run some BBQ skewers from the boom to the middle of the elevator to give it some rigidity. Does that make sense?
Nicholas7231
Yep, kind of like a brace for a high wing going from fuse to the wing, except for the tail in this configuration
Bavarian_RC
I have added rudder on one of the stabilizers of my FT Bronco. The effect in flight is not very big, but this is for sure due to the small size (depth 33mm) and the fact that I only did it on one side. I will rebuild the FT Bronco soon as it has now more than 250 flights and gets a bit soft. Especially the joint between the vertical stabilizers and the tail boom, but also at the connection to the hstab is getting weak now. But I think after 250 flights this is ok. For the new build I will go for a differential thrust solution.
In order to reinforce the vertical stabilizers of my current Bronco I had added BBQ skewers along the leading edge. Nevertheless I had to add more reinforcement after around 100 flights. I made 2 vertical score cuts on the inside of the vertical stabilizer and widened them to fit BBQ skewers. They go from the underside of the tail boom up to about 1/3 of the vstab.
Outside view:
Inside view:
It is maybe difficult to see, but the BBQ skewers are inserted where you can see the bulky lines
Nicholas7231
I just completed a flight, I added dual rudders similar to Bavarian Rc's setup. They work fairly well, you cant flat turn but they help with coordinating the turns. They really help in cross wind landings as the plane was torquing over when differential throttle was used, and now with just the rudders it's easy to glide in
m20m00a1
An old thread but thanks to @Bavarian_RC and @Nicholas7321 for the inspiration for functional rudders. Just maidened tonight in light breeze. I used a single servo and a "jockey bar" for rudders and it will flat turn pretty well with 100% travel. Leading edges of the stabs were reinforced with skewers as well as embedded skewers inside the vertical stabs. Running 28-30 propdrive motors with inboard counter-rotating 8x6 props. I have cheap 50A hobbyking ESCs and when I tested everything I'm within the motor specs. Tonight was a 3200 3s, but the next chance I get I'm going to try a 2700 4s. Pretty quick and a crazy roll rate.
