outthayr
HGLRC XJB F428-TX20 Omnibus F4 Flight Controller 28A 2-4S Blheli_S ESC 25/100/250mW Switchable VTX, RunCam Split Mini
Trying to follow along with HGLRC_F428-TX20_V2-manual and https://www.runcam.com/download/split/RunCam-Split-EN.pdf
So far I've managed to get connected to Betaflight, remap the motors and spool them all up.
I've had no luck getting the lemonRX to bind with a Spektrum Dx6e, and no luck getting a video output yet.
I also got some smoke to puff when I hooked up BATT from the FC to 5v on the VTX ... oops, instead of the 7-26v. May have cooked it completely? I've got a nano and a TBS unify I could use. (the diagram for the FC manual pictures a slightly different VTX model)
Does the LemonRX go to DSMX or SBUS or PPM? Does it LED/flash in bind mode? Does it pull 3.3v? Can I use a Betaflight CLI command to help bind with Spektrum TX? How does the Runcam pass through the FC and to the VTX? How does the OSD get integrated into this setup?
Any help is appreciated!
