leighb2282
Bright-Star mk.1
DETAILS
Howdy Folks, this is going to be a build log for my personal Cargo plane, Peter's Guinea Pig is an awesome design but I wanted to try something a little different.
I wanted to try to design and build a cargo plane from scratch, with my own twist on a cargo plane.
The basic rough concept is a mad love child of a C5 Galaxy, Embraer 390, YC-14 and potentially a little bit of Britten Norman Islander depending on how the build progresses.
FAQ
Will the BrightStar be swappable?
In a way YES! I plan to use the Guinea Pig nacelles dimensions in terms of width and height to allow for a certain compatibility with the dimensions of a power pod but design the nacelles and the power pod specifically fo rthe EDFs i'm going to use (EDF Power pods!)
Differential thrust or rudder?
I Plan for both, with the size its working out to be it may well be very fun to have the ability for differential thrust as much as an EDF will allow.
How many servos will I need?
Currently 5 (2x for Ailerons, 1x for rudder, 2x for elevator) I may well also add flaps before the process is over so 7 servos
What about landing gear?
Initial plans will be for fixed landing gear although I really want to scratch build some form of retracts for it.
SPECS
PLANS
None Yet, my designs when designing in Sketchup do not follow the plans standards that FT uses.
BUILD LOG
Stay Tuned!
REVIEW
Coming soon.
DETAILS
FAQ
SPECS
WINGSPAN | Roughly 60-66” |
LENGTH | Roughly 50" |
CHANNELS | 4-6 |
Weight | (Potentially a plump bird, my designs are not elegant) |
Build Difficulty | Unknown |
Build materials | Foam Board Hot Glue CA |
Planned Electronics | SPEED - 4S MOTORS - 2x 2x Alloy DPS Series 68mm EDF (66amps max, 4000kv motor, max 1000w, cont 900w) - 1 will be running with a normal impeller/rotor. ESCS - 2x HobbyKing 70A BlueSeries Brushless Speed Controller (cont 70amps, 90amp burst) BATTERY - ZIPPY Flightmax 4000mAh 4S1P 45C SERVOS - Currently cheap 9Gr micro servos, may have to move to some metal geared servos... |
PLANS
BUILD LOG
Stay Tuned!
REVIEW
Coming soon.
