C-Pack Twin giving minimal thrust
jakexie6
My twin C-Pack is not giving enough thrust to power my Guinea Pig. I give it full throttle and it pulls the same amount of amps that should be drawn from one motor. The picture shown was taken at full throttle connected to both motors. Any ideas on what's happening?
If your prop is on backwards, you’ll only get about half the thrust. I don’t care if you have a tractor or pusher setup. The numbers on the prop always go towards the front of the plane.
jakexie6
Props were on the right way. I've been so busy recently that it's been difficult to retest. Next time I'll check each motor individually too
