tristantrc
I’ve asked this question to local hobby shops and nobody can seem to help me so I thought I would ask you!! PLEASE HELP!
I'm building my first multi-rotor and I know nothing about flight controllers, PDB boards, and programming... I fly simple fixed-wing aircrafts.
The multi-rotor I need to build only has ONE purpose: to carry a heavy payload (5 lbs minimum) and drop said payload using a mechanical servo (like the ones FliteTest rigs up on their airplanes) attached to the underside of the drone.
I've been flying "fixed wing aircraft" for year several years now and I want to use the same equipment that I have to fly big airplanes to build this multi-rotor… such as my: FrSky X8R Receiver and Taranis QX7 transmitter, along with some BIG brushless (Turnigy SK3) motors, 80A Hobbyking speed controllers (w/sbec), swinging 13”-15" props, and mechanical servo bomb drops that I already have on hand from all my airplane builds... (That way when I’m not using the multi-rotor I can use the equipment back in my fixed-wing airplanes). I will make the frame using the same technique as in the old FliteTest "H-Quad" series.
The older "Naze32 Rev6" flight controller was most commonly used for these types of (PWM) based multi-rotors several years ago however I read somewhere that CleanFlight and BetaFlight no longer offer programming support for the old "Naze32 Rev6" flight controllers. Which SUCKS!!!
Is there a current flight controller on the market that is similar to the older "Naze32 Rev6" board that can handle inputs for servo functionality such as "bomb drops,” etc. ??
The ONLY purpose for this multi-rotor is to carry heavy (5lb - 8lb) bait out to sea from the beach when surf-fishing for sharks thus replacing the need to paddle my bait out on a kayak. I’m not interested in small, fast, race drones with tons of sensors. I need a simple, yet powerful multi-motor that can lift weight.. (I own an old "DJI Phantom 3" but it can only lift 2.5 pounds... not good enough for my application.)
I need to fly 400-600 yards off the beach and be able to hit a switch on my transmitter and have a mechanical servo drop the bait down to the water and I DON'T want to have to use 2 separate transmitters and receivers in order to achieve this... I would like to find a flight controller that can handle the entire operation.
Questions:
1. Is it possible to still build a multi-rotor using basic airplane parts? ... like the old "FliteTest H-Quad"
2. What kind of flight controller and PDB board do you recommend that is NOT outdated?
3. Do you know of anyone in the southeast who could mentor me and help me on this project? ... (I live in Alabama)
Thanks everyone!!!!
Questions:
Thanks everyone!!!!
