Donating the Cessna
Since I have too many planes and I will (most likely) never fly this one again I am willing to donate it.
Anyone around Birmingham, UK can come and collect. It will be frame only but already built and covered (all red)
Add your own servos, esc, motor and battery and away you go.
I need the space and I don't want to throw away so many hours of work.
Due to a combination of bad weather and lack of free time I have postponed the second maiden of this plane until last week. As a reminder, on the first try the weak undercarriage (front leg) just bent when trying to take off. I have reinforced the front leg with some extra 2.5 mm wire just to keep it straight. Finally, we had take off.
First, of all disregard the COG from instruction, my plane was flying balanced with the COG at 1/3 of the leading edge, and from the top of my head that is like 5 cm.
Second, this is not a beginner plane, because of the narrow(ish) wing it needs some good speed to fly.
Third, it's touchy, it needed a lot of dr (60) and 30% expo in order to fly decent.
Fort, even the metal main carriage is weak and bent easily on a hurried landing.
In summary, if you like building chinglish kits, than it' good. As a plane however, well... there are other a lot better there.
