Change XT60 to XT30 on battery charger
shadeyB
Hi,
I have this charger https://www.amazon.co.uk/dp/B0831G245T/ref=cm_sw_r_wa_apa_i_c.BLEbJHPJEKK
It only comes with cables to charge thru XT60
And this battery https://www.hobbyrc.co.uk/gnb-850mah-3s-80c-lipo-battery-xt30
Can I change the charging cable from XT60 to XT30? Is it safe?
Thanks!
whatever plug you use commonly on your batteries whether it is the XT60/XT30
remove unwanted plug from your charging leads and solder on new plug that suits your batteries
Bricks
When you make the change DO NOT cut both battery wires at the same time I did that once with out thinking and trashed a good pair of side cutters ( that was exciting ).. Now I work with one lead at a time, cut one solder then cut the other and solder.
BradDH
Ya, I made that mistake once when replacing the deans on my battery, but fortunately, it was really brief and everything was ok. Gave me a good scare though:)
