I am trying to figure the batteries to order for my FT Flyer, I have most of the parts figured out but trying to make sure everything can connect together.
Here is my shopping list:
On the way from ebay: GoolRC GC6 TX/RX
From Headsuphobby:
Emax CF2805 1300kv
Sky Power 10A ESC with Linear BEC
Power Up 9g AS181NG Analog Sub-Micro Servo
O-Rings for Prop Savers - Pack of Ten
From Hobbyking:
Linkage Stopper D2.1mm (10sets)(already have rods)
GWS Style Slowfly Propeller 10x4.7 Black (CCW) (5pcs)
GWS Style Slowfly Propeller 9x4.7 Black (CCW) (5pcs)
HobbyKing®™ Fire Retardant LiPoly Battery Bag (Flat) (230x140mm) (1pc)
HobbyKing™ Lipo Voltage Checker (2S~8S)
Accucell S60 AC Charger (US Plug)
I want to get a couple 460-500mah and one 1000mah battery, I found a 60gr 1000mah:
Turnigy nano-tech 1000mah 2S 25~50C Lipo Pack
It has an XT60 connector for discharge and JST-XH for balance which works since the Accucel charger has a XT60 to bullet adapter + balance plug.
But as far as using this battery with the ESC that only has a JST connector, I couldn't find anything. All I found was this "XT-60 to JST Charging Adapter (2pc)" but I believe that it is to charge a battery with jst connector to a charger with XT60 connector like this "7.4v 500mah 35C EZ Flite Lipo Battery"
Anyone know an adapter to use that XT60 connector 1000 mah battery with a JST connector ESC ? Maybe I am missing it and it's easy to find.. after a couple weeks researching things, I may be missing the obvious.
Thank you
PS: also if you see something really bad in my setup above, let me know, or if you know a place with light cheap and good batteries
From Headsuphobby:
Emax CF2805 1300kv
From Hobbyking:
Thank you
