RandomChaos
Being new to the RC Plane world, with a little experience in flying a custom built quadcopter, I've gotten a little confused on how to choose the right motor for a setup. I have a spare 980kv motor that I would like to try using on a plane, specifically my Blunt Nose Versa Wing, but am not sure if it would give me the results I am looking for.
Currently, I am running the Hextronik 1300kv on it, but it seems to be slightly under powered for my setup, especially once I start to try adding a camera and such. I'm not really looking for all out top speed on it, more of looking to have a fairly responsive motor at lower voltage levels, not an all out screamer. I was thinking the 980kv motor with its 10x4.7 prop would be nice, but i'm not sure. There is plenty of space for the 10 inch prop, so that is a non issue. In the world of quadcopters, with my limited understanding of it, usually as the weight of the quad goes up, you need to look at fitting larger props to get more "torque", thus needing a lower KV motor to handle the larger prop. Is it the same concept with planes? Do you go for a smaller prop / higher KV motor more top speed thrust, and larger prop / lower kv motor for more thrust at a lower voltage?
Sorry if this has been answered before.
