Someone commented that my plane was tail dragging and probably needed the CG moved forward. All 3 photos have the balance sticks sitting were the plans show that the CG should be. Photo A - all the equipment is were I had it in the clip (or as best as I can place it from memory). Photo B & C were me messing with balance points with the battery sitting on top (which ends up being slightly different then in the plane because of the vertical offset apparently. I will say my battery ended up quite a ways farther back then were the build video showed it getting put (you can see about were it ends up by looking at the photos from the top view, I just have it resting on the bottom layer of foam instead of on top of the plane.
So my questions
So my questions
