Twitchity
Tritium, I just emailed you the files for all 4 frame pieces, the long arm, short arm, and camera mount. Good luck with your build, and post pictures of the progress!
All frame pieces are cut! The power went out as it was making its 3rd pass around the perimeter of the top piece so the cut got reset Thankfully I had a nice guide line so I just used a cutoff wheel on a dremel to finish the cut, and then sanded it smooth. Won't even be able to tell.
Anyways, pictures! All frame pieces with the anti-vibration balls came in at 106g. I must say, this black and neon blue go good together
A little idea of what it will look like once the standoffs arrive:
Ooooowwww now dats wat um talkin bout!
