The needle and I ... some secrets reveiled...
...and talking about SPEED again....
By trying to make the needle cutter as smart as such a simple "tool" can be, I made up my mind about the "real" function.
We were discussing (a few times) the sense (or nonsense) of trying to shorten the time for a project by making the process faster...but the limit for that is not too far away.
So I tried out to find the reason for this limit in looking a little more closely......
What will we see, when the needle is working? --> we see a fast punching needle and an advancing router/mill....so it seems to be easy to say: " if I'm going to increase the feed speed...I only have to crank up the motor revs for the needle the same percentage" ...but as said before: this is not true...it's not "linear"...but why?
Let's have a look how a sewing machine is working...
...the machine is advancing the fabric while the needle is up...then it makes a stop and the needle is going down and up...and the fabric will be moved one step further ----> there is No sideforce on the needle!!!!
Our system works a little differend ---> the needle is going up and down and the router is advancing continiously
This will create a sideforce, because the CNC is traveling, even when the needle is way down in the material....so we have friction in the guide and friction in the material...
The effect will encrease if the material is thicker...then the needle will nearly beeing forced to bend in the "hole"
OK...but one can say" if I crank up the needle, the time in the hole will be shorter....and can travel with more speed!
Sounds realistic at first...but is not!
---> the cutting/punching of the needle is generating heat within the material - even without any sideforce (I got smelling/melting Depron
---> the movement of the needle in the guide is generating heat too (and some early weareouts of the guide and the needle)
---> sometimes you will run into resonances and vibrations (on/in the parts to be cut)
My suggestion to SPEED is:
---> find out the optimum for your system and a certain material (depron is much differnd to cardboard
---> and then go SLOWER by ~30%!!!!
---> this will produce nice results and a real long lifetime of the cutter (with a little mainternace/oil)
So stay cool and slow down...
Joachim
BTW
who knows this machine?
https://www.inventables.com/technologies/x-carve/customize#750mm
I need some infos on the rails
