dkj4linux
All,
Thurmond "Tritium" Moore informed me that several FliteTest "residents" ("RAM", "Bricks", "Tritium", etc.) had discovered my CNC-driven foam cutter... I found their posts in the "$150 Laser Cutter" thread. After snooping around a bit more, it appears there is interest in an economical alternative to lasers, modified plotters, sewing machines, etc. for cutting foam sheets.
Basically my foam cutter is a very fast reciprocating needle -- like a sewing machine -- mounted on your CNC machine. Set in a feed rate that yields 10-15 strokes/mm and you can cleanly cut DTF (paper on), blue-cor fanfold foam, etc. Pin a sheet of foam board onto the bed of your CNC, load in the plane's gcode, set the origin, and start the machine. Twenty minutes or so later you have a sheet of parts that are accurately cut, easily punched out, and hot-glued together. Score cuts are no problem.
The foam cutter itself can be built and easily adapted to your CNC machine for less than $20 worth of parts (less if you're a scrounger) and a little bit of your time. If you are interested in building one for yourself, I'm more than happy to monitor this thread, answer questions, and further interact here but rather than repeat *everything* I'll also provide (in a following post) links to other threads/sites that deal with the active design/development of this foam cutter and Ryan "Allted" Zellars' fantastic Mostly Printed CNC... and provides you with all the information you need to build and adapt one to your needs. -- David "dkj4linux" Johnson
