Cool beans, I was hoping you had something smaller than the common 2200mah which is a bit much for this build.
A few things right off of the bat;
1: You only need to make the "F" hatch. I did not make that very clear in the build guide. The E or F hatches are an option and completely interchangeable. The skins are going to use the F hatch though. I think the Rhino just looks better as a 2 seater. The legacy Hornet looks better as a single seater though.
2: Hand launches are a breeze if you hold it by the LERX, (leading edge root extension).
3: Your elevators are going to need to be in a slight pitch up attitude. If they are completely parallel to the wing you are going to need to add a bit of uptrim to achieve level flight. I good place to start is at the forward tip of the elvator, it will be about one layer of foam below the wing plate. (I will take a picture and upload for a visual)
Hex blades as promised
https://www.amazon.com/dp/B01NCEO5DI/?tag=lstir-20
And of course if you have any questions, just post here I will answer ASAP.
