Devil's Dozen - Sky Screamer by FoamyDM (Crimson Skies Concept)
FoamyDM
Building Fool-Flying Noob
This build was thought up and planned out in the throes of the flite test fantasy design-build challenge by @rockyboy. I got silly with the whole thing and just plum run out of time literally by days but here is the plane for you to enjoy.
This is my last design in this series, mostly because it's the last of the six depicted by the artist. Below you'll find the build log showing the finished product or at least the nearly finished product, I predict it will fly quite well and fast on an f pack motor
Specs
F pack motor power system
800 milliamp hour battery
2-5 g servos.
5 inch prop
30 in wing tips pan
15 in nose-to-tail
Build log
This isn't a whole lot different than the spitfire. What I did was I ironed the trailing edges to a thin taper and the front non fold over edges I curled with the iron just slightly ended up on all control surfaces. The bone cut out I remove the paper from the back and curled it to form a little bit better as well as pinching of the thin parts to kind of give it the rounded bone like shape and kind of the rough edges and turn up pretty well. I plan to take string and essentially fasten those bones to the fuselage and the way they have in the picture but I wasn't going to do that tonight.
Here's some pictures:
IMG_20190302_024321213.jpg IMG_20190302_024447117.jpg IMG_20190302_024508164.jpg IMG_20190302_024719515.jpg IMG_20190302_024729422.jpg IMG_20190302_024749677.jpg IMG_20190302_024757790.jpg IMG_20190302_030135408.jpg IMG_20190302_030145316.jpg IMG_20190302_030203869.jpg IMG_20190302_030228512.jpg
PLANS
kilroy07
That works amazingly doesn't it? It's by far the neatest skill I've learned for foamboard airplanes thus far!
