Differential thrust with throttle cut
Paracodespoder
Sounds like you need to mix your other channel (the one you’re using for your extra motor) with your cut switch. Don’t know that you can or if it will work, but that’s my guess. Good luck.
mayan
That's my guess too program it up like you would do with flaps.
jpot1
Hopefully this helps.
Headbang
I managed to do it too on my seaduck, had a -100 offset on the second motor. I also had a mix to 0 out the rudder as well so nothing would fire on rudder input.
Mr NCT
VP of SPAM killing
Resurrecting this thread after setting up differential thrust on my Sea Duck with a Spektrum DX6e. Hope this saves someone some heartburn. I followed the FT video but didn't like that there was not a true throttle cut - if you hit the rudder the right motor would still turn. Found this video and then transcribed my settings:
Throttle Cut & Differential Thrust Spektrum DX6e
Rx connections: Left motor – throttle, Right motor – Aux1
  • Function List
    • Set Throttle Cut to SW3 pos 0
  • In system set up:
    • Channel Assign
      • Rx Port
        • THRO: Throttle
        • AUX1: Aux1
      • Channel Input Config
        • Thro: N/A
        • Aux1: Inh
  • Function List
    • Mixing
      • Mix 1 (links throttle to aux 1)
        • THR > AX1
        • Rate: 100% 100%
        • Offset: 0%
        • Trim: Inh
        • Switch: On
      • Mix 2 (applies throttle cut to aux 1)
        • THR > AX1
        • Rate: -100% 0%
        • Offset: -100%
        • Trim: Inh
        • Switch: G, Pos. 0 active (pick any 3 position switch)
      • Mix 3 (applies diff thrust to throttle – left motor)
        • RUD > THR
        • Rate: -20% -20% (set to your preference)
        • Offset: 0%
        • Trim: Inh
        • Switch: G, Pos. 2 active
      • Mix 4 (applies diff thrust to aux 1 – right motor)
        • RUD > AX1
        • Rate: 20% 20% (set to your preference)
        • Offset: 0%
        • Trim: Inh
