Help! Does this motor work?
mastermalpass
mastermalpass
Ooh, how big is this plane? 8x6 props are typically for (what I consider to be) medium sized planes that want 1600kv motors and 30a ESCs. Most planes of that size will fly with a 6 inch prop but you want the headroom, ideally.
Magne
It is because i have a plane that weighs 400 grams and the thrust a 8x6 prop can make is 800 gram.
I already have a 6x4 prop at home and wanted to know if i can use that one even if it is not recommend for the motor.
...I already have a 6x4 prop at home and wanted to know if i can use that one even if it is not recommend for the motor.
A prop, smaller than recommend, is perfectly fine to use on a motor. A prop, larger than recommend, may cause the motor to draw too many amps and over heat.
mastermalpass
400 grams is in the low mediums for me. 6x4 prop will be fine there - my RC Powers park jets use that. But after a couple minutes of flight, I recommend you touch down and feel how hot that 20A ESC is getting. The ESC is the bottleneck in this set up.
Weight is one factor - drag is another. My latest parkjet doesn't weigh much more than my previous one, but there is more drag (the wing's 50% thicker), which demands much more power. Fortunately the ESC is a 35A.
