Foam Addict
Squirrel member
This tutorial should help you rewind any CD style motor, and gives a basic DLRK or AabBCcaABbcC winding guide.
Each post will encompass one "phase" of the motor, with all teeth in that phase being wound with one strand of wire.
My specific equipment:
DT-750 motor.
Tech Fixx 22g 200c wire.
Wire cutters.
Exacto knife.
First, pick any tooth. This will be tooth one. Wind 16 turns clockwise as neatly as possible while leaving a 2-3" tail of wire. This is the "A" tooth.
Next, move one tooth to the right, and wind 16 turns counterclockwise. This is the "a" tooth.
After that, move 5 teeth to the right, and wind that tooth with 17 turns counter clockwise (I'll explain why later) ,This is the next "a" tooth.
After that, move one tooth right, and wind that tooth with 16 turns clockwise. This is the "A" tooth, and it also completes the phase.
Leave a 2-3" tail, and clip the wire.
While you are at it, scrape the insulation off of the end of the wire wire, and check for shorts to the stator with your multi meter. If there is a stator short, you will have to unwind the phase and try again.
Now that wasn't so bad was it?
Only two more to go!
DT-750 motor.
Wire cutters.
Exacto knife.
