Shurik-1960
1. Disassembling the engine. 2. To remove the stator coils, I put them in a dry frying pan and heat them for 10-15 minutes, then disconnect the parts. You can not do this with pliers - you will damage the enamel protection!!! 3. I remove the wire from each phase and count the number of turns. 4. I paint over the chips with 2 component epoxy. 5. 1 meter of wire and I start to wind: I need -17 turns, but in fact - 14 turns per tooth. 6. I wind according to the color scheme: 14 turns clockwise and 14 turns counterclockwise, a transition of 180 degrees and 14 turns against the clock + 14 turns clockwise. Hurrah- 1 phase is wound up.
Dear modelers, please do not ask questions until I finish putting up the photo and the story definitively.
