randyrls
Randy
I bought a speed build kit, but rather than putting it together, I thought of using it for a template to make a new one out of blank foam board (FB).
I want a cutter to cut along the template and into the FB underneath. I found a cutter by FoamWerks (sp correct) WC-6010 that I think will fit the bill. It can cut at variable depth and both vertical cuts and 45 degree bevels. It may or may not work for cutting bevels in control surfaces and wing leading edges.
I next want a a scoring tool that will cut the rabbets for folds and joins. Didn't see anything that would fit the bill. A small block with a blade on the edge of the block with a guide of plastic so the blade and guide are separated by the thickness of the FB is what I intend to make.
Am I overthinking this????
Any suggestions are appreciated and expected.
Let the brainstorming begin!
