I picked up a Goldberg Electra Sailplane from a local hobby shop that was closing down this summer. The builder did a great job with this plane - straight and true without a wrinkle anywhere!
It has the original designer recommended speed 400 brushless motor and speed controller - a rather chunky 9 ounces up front that combined with the mid 80s NiCad battery packs contributed to this plane being rather heavy and having a reputation for not so great performance.
So I'm going to replace that power system with a modern brushless Eflite 450 that should swing the same prop quite nicely at only 3.7 ounces. And the Lipo will be lighter than the old battery too, so overall it should be 7 or 8 ounces lighter.
Since the existing firewall holes are in all the wrong spots, I cut and drilled a new firewall.
Good old Titebond and a clamp works to glue the new firewall right onto the old one.
And now there's a brushless motor up front!
Yes, mounting this way will let the motor hang out and be visible.... Unless I can find some sort of cowling tube or spacer.... Not that excited about trying to find a brushless motor I could mount behind the firewall when I have this one sitting in my drawer already.
Next up - put the prop back on and do a balancing act!
