Hi,
I've been flying RC planes for about a year now but this is my first multi-rotor build. I'm building the Electrohub in a quad X configuration using the naze32 board from FliteTest and the power combo from Altitude Hobbies. I've got it built and I followed the steps in the naze32 setup video (http://flitetest.com/articles/naze-32-board-setup). I followed the steps in the video exactly except that I did not check the box to prevent the motors from spinning up when the quad is armed. I used a piece of 0.25" latex foam rubber wit hdouble sticky tape on both sides to mount the control board to the upper plate. I thought this would isolate the control board from vibrations but maybe this is too soft and is causing problems?
I took the quad outside to maiden it. I armed it and advanced th throttle slowly hoping to bring it up into a hover 1 or 2 feet from the ground but with just the tiniest throttle input the thing shot up about 20 feet in the air! I cut the throttle but it didn't seem to be coming down just floating up where it was and starting to go out of control. A little panicked I flipped the arming switch to cut the motors and it came tumbling down to the ground but luckily only the zip-ties broke.
I thought that maybe I had set the minimum throttle too high so I lowered it to a setting about five clicks before the first motor started spinning. I also increased the "Throttle Expo" setting in clean flight by about 25% I think. I took the quad out and tried again but got almost the exact same result. This time two of the booms cracked. My PID gains are all at the default values. I've read that the over sensetive throttle may be due to a too high P value but there is not a P for throttle. I see Roll, Pitch, Yaw, ALT, and VEL. Should I reduce the P-gains on all of those by say 25% and try again?
Both flights were in acro mode. No auto-level.
Thanks,
Daniel
Thanks,
Daniel
