EZ Bronco
EZ Bronco 1.5
Please log in to download
Well, not having any luck getting dRonin running on the board but have Betaflight running with 2 motors mixed correctly. So this is a GO! Adding servos will be a bonus but looks VERY doable. On to cutting foam!
What size brushed motors come in the FT brushed kit? (Height/width/propsize)
Rather than cluttering up your thread further, I have created a build thread documenting my builds.
AgentC
The 2-channel comes with 7x16, I think...
The 3-channels used to be 8x20, if I remember correctly.
Looking forward to following your thread!
AgentC
Getting started on what I'm currently calling the "UnEZ Bronco"!
Yankee2003
Well done. A triumph of design and perseverance. I can’t wait to build and fly one.
You should feel very proud of your accomplishment.
AgentC
BETA versions of the Un-EZ Bronco are attached here.
The canopy needs to be tinkered with the get it to align properly, but if you enjoy a trickier build for a silly easy plane, then this is yours! The end result is definitely worth it, and this little gem flies just as well as the profile version (once you get the CG right).
  • UnEZ Bronco v1.1 (CAL FIRE) - 6x LEGAL PAGES.pdf
  • UnEZ Bronco (v1.1) - (3x Letter Tiled).pdf
AgentC
AgentC updated EZ Bronco with a new update entry:
Un-EZ Bronco (BETA) files are added!
BETA (regular and CAL-FIRE skinned) versions of the Un-EZ Bronco are attached here.
Read the rest of this update entry...
Finally picked up a FT EZ power Pack V2. Have a few months to finish my build before indoor season starts.
AIRFORGE
Make It Fly!
I cant seem to find the foam thickness or electronics for this bird. Maybe a build video? I am a newbie to the building.
Approx. 3/16 in, 4.5-5.0 mm.
On the FT STEM Store (STEM Electronics) look for the FT STEM 2ch EZ Power Pack V2
CockerFanatic
Long shot here! I will make a post on its on somewhere on the forum.. only reason i made an account is because i seen his profile. He is an older vetran friend (i didnt serve) we bought sold and traded alot from each other on paintball forums years back.. but did any of you on here meet @FeWolf ? (Scott) I've been trying to find him for literally years as I have an older paintball marker I've had of his for years and it got pulled from storage and been trying to track him down.. would be awesome to get ahold of him. And would be forever grateful if someone on here had some kind of way.. or even a way to tell him to get on here again and check his message. Thanks guys
AIRFORGE
Make It Fly!
If @FeWolf has notifications turned on, he will see you have tagged him in your post.
He has not been back to the forum since late 2022.
