IT'S HERE!! THE F-4 IS FINALLY HERE!!
This is one project that I've actually been working on for quite a while, without posting ANYTHING about it here. I built #1 at Flite Fest Ohio, 2017, and it flew AWESOME. Flite Test even featured it a bit in their recap video. Ever since then, I've probably gotten more requests for plans for this jet than any other - which puzzles me because it's clearly NOT a trivial build!
But you all asked for it, and I promised I'd post plans when I finally flew my second build at home, so here you go! I'll put up as many build-pics as possible, but fair warning; they're not comprehensive. O_O So please ask questions as you go, I'll try to answer them as best I can, and hopefully others can learn along at once.
Details:
F-4 Phantom II
Power: 2 x 70mm 12-blade EDF
Battery: 5000-6000mAh, 4S
Wingspan: 36 inches
Length: 54 inches
Weight: 85 ounces - (5lb, 5oz) - (2.4Kg)
DISCLAIMER: As of this post (11/2/2017), the plans are posted in "AS-IS" condition....meaning I still need to make some updates, but it flies, but be warned. Mostly, I need to move the motor-mounts BACK to make room to move the battery and ESC's back as well. If you build it per-plans, most likely it'll be nose heavy - which isn't bad, just not ideal. But I've kept this to myself long enough, I feel like it just needs to be out there for everyone to have fun with.
Also, you do NOT have to build the all-flying "Stabilator", you can get away with traditional elevators on a fixed horizontal stab. However, you will need two servos; one for each elevator.
PLANS:
https://forum.flitetest.com/index.php?resources/f-4-phantom-ii-twin-70mm-edf-monster.274/
Build pics below:
Sorry there aren't more details on the build. If I find more, I'll post them. If you DO attempt this plane, PLEASE ask questions here so everyone can benefit from the answers!
Details:
F-4 Phantom II
Wingspan: 36 inches
Length: 54 inches
PLANS:
Build pics below:
