SGrog
Good day all!
I have had some experience with fixed wing aviation in the past, and am hoping to build a large bird that would be intricate in terms of capabilities, but simple in design, etc. The plan I am designing, for the full scale design will have a 12' wingspan based off of my figures and the fuselage will be around 6 inches or a little more wide.
Before I build the giant, I am going to develop a scale 4' wingspan of what I intend to develop, and not put any of the advanced components on, as I will develop those separately on the side. I will primarily build it out of balsa, and there is a place locally that you can rent a laser cutter, which is what I plan to do.
My questions are how do I make sure I have enough support to hold up the wings under large wing loads; Second, Im guessing here, but the whole assembly might be 25-30 lbs, how would I choose motors that can produce enough thrust? Im not looking for acrobatic type characteristics, but something that would fly like a C-130 or similar aircraft.
General Information about final design:
Again, I would not start out designing the above, but a basic flying proof of concept, and designing the gear, bay, and pod seperately, and integrating in the final design.
Is this unrealistic, or what are peoples comments?
- 12' wingspan, likely a root chord of 12-14", wing up high similar to a Cessna 206
- Likely powered by two electric motors, but would like to fly with one if one fails.
- Fuselage between 6 and 8 inches wide, and equally tall, up to 9 inches tall
- Fuselage would be around 5' long, with a twin tail like a B-25
- Retractable landing gear similar to a PBY Catalina
- Central "bomb bay" underneath wings essentially
- Rear camera pod that would drop down like a B-24 bottom turret when in flight
- Front mounted camera in nose
- Hard points if possible.
