So I bought this combo (http://www.hobbypartz.com/60p-dy-1026.html), and hooked up a smaller battery to it (1200 3s 15c) and it worked fine. I cut the connection to the battery to put a different connector on it, but when I cut the battery, for a split second the two blades of the scissors touched each wire and some smoke popped out. Now it seems the battery doesn't hold a charge. Charger says connection error and no power to esc. So I'm looking into a bigger battery to put up front because it is a little tail heavy.
So I was looking at a 2200 20c 3s battery, is that to much for the 18a esc?
Or would I have to buy a bigger esc for that battery? Then would the motor be ok?
Any input would be great.
Thanks.
Thanks.
