Hi all,
Total noob so your patience is appreciated
I have ordered a Batbone kit and while I wait for my parts to arrive, I thought I would put figures into the ecalc website with the parts I've ordered to see what I got. Ive attached the results. I have a red warning about exceeding the the max current for the motor.
I've read on some other posts that this is not a figure to worry about and that it is the hover figures that is more important. Is this correct? If not what should I have bought differently?
Do you need to use 100% of the throttle? How do you prevent this? Limit settings on the TX?
I'm confused really as the parts I have used (other than the ESC's) are on the recommended page for the Bat Bone.
Motors http://hobbyking.co.uk/hobbyking/store/uh_viewItem.asp?idProduct=36809
Battery http://hobbyking.co.uk/hobbyking/store/uh_viewItem.asp?idProduct=26715
ESC http://www.hobbyking.com/hobbyking/..._motor_speed_controller_simonk_firmware_.html
Props http://hobbyking.co.uk/hobbyking/store/uh_viewItem.asp?idProduct=35234
I tried modifying the ESC to different rated ones but to no effect so Im confused as to how that Maximum motor amp figure is achieved?? By changing the prop size to 6" I can get rid of the warning but I'm not sure what to do or if I have ordered something wrong. Or am I worrying about nothing??
Thanks for your help/advice
