armageddon
Hello everyone,
I am a newbie at multirotors and i need some assistance with a tricopter i would like to build.
I have comprised a list of all the items i am buying from HobbyKing and i was wondering if you guys could maybe improve it or help me to cut back on costs where possible. The list has to have everything in it that is required to create and fly the tricopter (excluding tools such as soldering iron, wire cutters, etc).
This is designed off of the RCExplorer Tricopter V3 video.
At the moment the list is around $260 and i dont want to go too much higher, unless it was really worth it.
Here is the list:
3 Turnigy Multistar 2209-980Kv 14Pole Multi-Rotor
3 Afro ESC 20Amp Multi-rotor Motor Speed Controller
1 Hobbyking X900 Tricopter Glass Fiber Multi-Rotor Frame
1 Hobbyking KK2.1.5 Multi-rotor LCD Flight Control Board
1 Turnigy 5X 5Ch Mini Transmitter and Receiver
1 ZIPPY Flightmax 3000mAh 3S1P 20C
1 HobbyKing HK-922MG Digital Metal Gear Servo
1 Universal Propeller Balancer
1 Turnigy 12v 2-3S Basic Balance Charger
3 Super Bright 3Watt LED Lamp
4 Turnigy Pure-Silicone Wire 18AWG (1mtr) Red
1 XT60 to 3 X 3.5mm bullet Multistar
1 60CM Servo Lead Extention (JR) with hook 26AWG
4 Turnigy Pure-Silicone Wire 18AWG (1mtr) Black
1 Cable Ties 160 x 2.5mm Black
1 10 x 5 Thin Style E-Prop Green CW
1 10 x 5 Thin Style E-Prop Green CCW
1 HobbyKing Super Glue CA
1 PolyMax 3.5mm Gold Connectors
1 Twisted 10CM Male to Male Servo Lead (JR) 22AWG
1 Servo Splitter Lead 1 Female to 5 male
1 Turnigy Heat Shrink Tube 30mm Black (1mtr)
1 Turnigy Heat Shrink Tube 25mm Transparent
1 Double Sided Tape Pack
1 Turnigy 4mm Heat Shrink Tube - BLACK
1 Turnigy 2mm Heat Shrink Tube - BLACK
Here is the list:
