Beaver5150
I'm new here, but Ive been on other forums and in the hobby for over 10 years. This is my 3rd Multi-rotor build in a few months, each one morphing into the next.
This one isn't pure scratch, but made from an Eachine tilt rotor 180 frame and parts of a wrecked MSH Mini Protos 450 heli and are spliced together at the mid section. The motor mounts are from a Tarot Ironman 450 quad, and the landing skids are MSH.
Electronics consist of AR6200 Diversity 6ch Rx, an older Illuminati32 (Naze32/F103) controller on Betaflight, Castle 25A ESCs, 2- T-Motor 1806/2300kv motors up front on the steering arms, and a single 2206/2300kv on the tail, Gemfan 6042 x 3 props. . Steering and "bomb/cargo release" servos are F.T. ES08AII. I plan to upgrade to 25mm or 28mm motors and 7 inch props soon.
Programming the controller was a pain as I'm new to Betaflight, and the default configuration profiles wont automatically assign the proper servo outputs. I had to research and enter the proper CLI commands to get it working.
The Stinger started as an experiment, but after putting a few flights on it, I've decided to keep this one for awhile. It flies like a mix of helicopter and a quad, with a little airplane thrown in there somewhere. I have nearly 2 solid hours of flight time on it now, 5 minutes per flight on a 3S/3600mAh/50C pack, which isn't bad considering the 800g flying weight.... and that's 5 minutes of fast flying, not just hovering around. The front steering works perfectly, no yaw problems whatsoever.
The LEDs are generic 12V strips and are necessary as I do most of my flying after dark due to my work schedule. This tricopter is a blast to fly at night, ripping around looking like a small UFO!
Well, there it is. I'm including pics now, and will have video soon. Questions are welcome.
