just did my first maiden with ft p40 which didn't went as planed and it crashed before landing. I am looking for suggestions to repair it effectively should i use balsa or just card boar as damage is on wing tips and front face is compressed with rankled foam.
That's a shame it was a nice build too. If it's any consolation I have been there myself and with a little time and patience you can repair that damage.
Here is my Sea Otter after a spiral nose dive from height
Here it is after a nose rebuild
I only finished building the FT Duster in February and after only 2 flights it got damaged while in storage in my attic, the wing ended up getting ripped off. That's also now back together and ready for another flight.
I've spent the last couple of weeks repairing my Edge 540 which also sustained damage to the wing in my attic, as well as needing the motor angle adjusting, cowl repairs and landing gear modifications. That model is also now fully repaired and ready to fly again.
On the Edge wing one of the ailerons had been completely ripped off, the plastic hinges had caused a lot of damage to the foam. I had to cut out the damaged section and fitted new foamboard inserts.
So don't give up on it, take your time and start by repairing small areas first, moving on to larger sections. For wing or tail section repairs I use bracing like carbon fiber rods or wooden skewers (I've used popsicle sticks if necessary on the fuselage for bracing). Always make sure you add the same bracing to both wings, so the weight distribution is equal even if the other wing has no damage. If a part can't be repaired then rebuild and replace it. I completely replaced the nose of the Sea otter and spliced the new section back on.
