As I am on the mend I snapped some images of the first two parts supplied by our friends at Hobby King.
Sullivan has been making hobby parts for years right here in my home state of Maryland, right down the road in Baltimore. Their experience has been shown many times by releasing products that just work. Their Skylite wheels are exceptionally durable for the weight. Their hubs are over-engineered to handle all sorts of awkward situations and there is enough "meat" on them to be drilled out for larger axles. The design uses a foam core with a robust urethane outer skin that is durable. It reduces bounce on landing and prevents flat spots when a model sits for awhile. I certainly am happy to use these as I expect the landing and take-off speeds to be higher than most most models I fly.
Next are the
140mm oleo struts. I've used this line of oleos on my Sikorsky build and I have been very happy with them. They are a strong alloy that handles loads well. They come with nylon spacers for the wheels and I will outline other features below.
How the assembled leg will fit into the model. Be mindful that I need to also use a retract module.
39g for the oleo... the same weight as stated on the Hobby King website.
48g for a
3" wheel.
The axles use a flared end to retain the wheel and these two grub screws secure the axle to the oleo. It is a secure way to keep the axle in-place. I've used other name-brand oleos that use a single larger grub screw and I like the redundancy here.
The oleo is secured to the retract unit using the same dual grub screw setup. Again, I love the redundancy. The retract mounting pins that are included have a flat spot for these grub screws to keep the oleo aligned.
One quick tip that I will give is to use a little bit of the graphene dust you can buy for pinewood derby cars. Alternatively, take a pencil and some 400 grit sandpaper and you can make your own! It will reduce rolling resistance and add a bit of "weathering"
I hope to make a little progress this weekend. I do have plans to do a little flying with some of my buddies from these pages.
