FliteTest in RealFlight 7.5 (Model Index)
Folgore88
@SquirrelTail I absolutely love flying the FT Edge! That's been the main reason I have been able to improve flying 3D as much as I have!
Hi and thanks for adding FT Edge to realflight, really nice work. I have imported into RF9 and it seems to work fine. I am a beginner for flying aerobatics so I am building my first FT Edge 120% to learn.
I would like to ask you how similar is the simulator to real flying?
tanmaychhatbar
If you're learning, I'll suggest keeping the plane in sim on low rates. That's still closer to high rates on the real thing with 9g servos. Apart from that, flight characteristics should be fairly close.
To answer your question, even the best sims will have their quirks, and won't be 100% accurate. Sims are most useful to set muscle memory, whether you're learning figures-of-8 or weeble wobbles. There'll still be a learning curve when transferring that knowledge to rc flying in real life, except you're getting a head start and reducing the chances of you crashing your plane.
Folgore88
I agree with you, after flying with the similator for more than a month, I flew my first model plane and was able to take off and land without any problem.
What do you mean "keeping the plane in sim on low rates" do I have to configure something on the simulator ?
tanmaychhatbar
Realflight allows you to switch rates. Check your channel assignments to find the button on your transmitter that's assigned to that feature! Have fun!
ogismycopilot
A huge thank you goes to AlternativeRC for stepping up to the plate with the required (outdated) software and skill to make it happen. He will be working his way through the existing FliteTest models I created for Phoenix RC and converting them for RealFlight 7.5. The wait is over, people!
FliteTest planes are now (FINALLY!) being ported to RealFlight 7.5. This post will be updated regularly as more planes are converted.
To install:
  • Click the link below for the plane you want.
  • Save the RFX file in a location you'll be able to find it.
  • In RealFlight click Simulation > Import > RealFlight Archive (RFX, G3X)...
  • Locate the RFX file you saved.
  • Click Open and fly!
Currently Available
Name​
Version​
Updated​
Description​
Download​
FT DR-11.001/04/2017The Tiny Triplane!
FT Duster1.001/04/2017Dusty!
FT Arrow1.012/26/2016Debut model conversion by AlternativeRC for RF 7.5!
FT MESA ALPHA1.001/24/2017Waterproof Foamboard Skin
FT MESA BRAVO1.001/24/2017Waterproof Foamboard Skin
FT MESA CHARLIE1.002/22/2017Waterproof Foamboard Skin
FT MESA ALPHA w/ BRAVO Wings1.002/22/2017Waterproof Foamboard Skin
FT MESA ALPHA w/ CHARLIE Wings1.002/22/2017Waterproof Foamboard Skin
FT MESA BRAVO w/ ALPHA Wings1.002/22/2017Waterproof Foamboard Skin
FT MESA BRAVO w/ CHARLIE Wings1.002/22/2017Waterproof Foamboard Skin
FT MESA CHARLIE w/ ALPHA Wings1.002/22/2017Waterproof Foamboard Skin
FT MESA CHARLIE w/ BRAVO Wings1.002/22/2017Waterproof Foamboard Skin
FT SE-51.001/12/2017Mighty Mini SE-5
FT Storch1.003/12/2017Luftwaffle Breakfast Bomber
Images
FT DR-1
FT Duster
FT Mini Arrow
FT MESA ALPHA
FT MESA BRAVO
FT MESA CHARLIE
FT SE-5
FT Storch
I intend to build the FT Tutor MKR2 with Turbo Wing Kit, and I'd like to practice flying using RealFlight Evolution, but the FT Tutor is not an available model. Which would be the closest model to use? Would it be the FT Storch?
FlyerInStyle
Maybe something like a timber could be quite accurate, the timber flies a bit floater but still around the same start with an apprentice working your way down to gyro off and then try something else like a timber
