FlyerInStyle's P.1079 chuck/ez pack glider
FlyerInStyle
Done with v2 (or should I call it v1.1) also, is there any way you can either shift ownership of the thread to me, or rename it to FlyerInStyle's P.1079 chuck/ez pack glider? here are the plans. I have not figured out margins yet though. sorry! this is the best I can get for now. there will be a couple blank sheets in there.
  • p.1079 chuck glider.pdf
FlyerInStyle
THANKS!!!!! also, the good tiled plans done! v2 made for the ez pack. just in case, I left the slot in the front for nose wight. that is, if required. pls try this out. I just need the size of the props to measure out where to put the motors.
  • p.1079 tiled new.pdf
FlyerInStyle
ok, so not knowing where to include these other than the resources page, I made the full chuck glider plans:
  • p.1079 chuck.pdf
JasonK
Participation Award Recipient
I didn't remake it and other then a really simple test, it hasn't been tested.
Jesse Dupreez
are these the same as on the resource?
