I am new to RC Airplanes and wish to use the MIX feature in my FlySky T-6 Transmitter to mix my ailerons and rudder for smoother flying. The transmitter is set up in Mode 2 with the ailerons (Ch. 1) as the master and the rudder (Ch 4) as the slave. The (+) positive mix is 50% and the (-) mix is 50%. There is also an offset percentage which is currently 0% (I do not understand offset).
Can anyone explain to me how to properly use this feature for the desired results and possibly suggest proper settings. Any help would be greatly appreciated and I thank you in advance. I currently have my dual rate set at 75% Rate and 40% Expo.
Best Regards,
Charlie
Best Regards,
Charlie
