MrKilometer
Hi all,
I'm having some issues with setting up differential thrust on an FT Guinea Pig. I'm using a DX6i, and have one ESC going to the throttle channel, and the other to the aux channel. The mixes I'm using are as follows:
Mix 1: Throttle -> Flap
U -100%, D -100%
Mix 2: Rudder -> Flap
R 25%, L 25%
When I throttle up, the motor attached to the esc that is connected to the throttle channel works, but the other one does not. The interesting thing I noticed is that when I set the "up" percentage on mix 1 to greater than 0%, the other motor (the one connected to the aux channel) works, and adding a greater value on the mix causes the motor to spin faster (so 10% mix gives 10% throttle, etc). It's worth noting that I have gotten differential thrust to work with this transmitter and plane, and these problems started when I replaced the Flite Test 35amp ESCs with Xilo 40amp ESCs and an external BEC.
I know this is a niche issue, but any help would be appreciated. Thanks!
U -100%, D -100%
R 25%, L 25%
