FlySky i6 endpoints issue...
CthulhuJon
I'm setting up a mix from Ch1 ( aileron) to control CH6 for second aileron, so far it works fine...
Then using the throttle stick for a mix for flaps... 2 more mixes for that... controlling Ch1 and Ch6... still all good...
Now the throws are too large on the ailerons, so I'm reducing the end points for Ch1 to 50%.. looks good on Ch1...
But... I cannot adjust the end points for Ch6 in the flySky settings... as there is no stick attached to Ch6... I can only adjust the minimum value, not the max value.
It works on Ch1 as you move the stick to the max position... then adjust. but how to do this for Ch6 ?
you would think that the 50% setting on Ch1 as master, would then also apply to Ch6, but it does not... it sends Ch1 to Ch6 before applying the 50% end points on Ch1
FlamingRCAirplanes
Yes, go on aux channels and assign channel 6 to one of the switches, after that do the same thing you did before, but this time flip the switch and it should work, then when you are done just unassign the switch
